Group: DynoMotion Message: 12719 From: Santiago Date: 1/19/2016
Subject: Can not move axis when Limit swich on
Hallo , I conect the limit swith to the mill, and they work fine, once they reach,Kflop   stops the table, the problem is to move it after that.
In mach 3 when the table reach the limit , an error ocurs and everything stops, then you restart and while limit is presed you can move the table to the other side.
But in  Kmotion CNC I do not see the way to do it. I restart and when I try to move it , it stops again
Este correo electrónico se ha enviado desde un equipo libre de virus y protegido por Avast.
www.avast.com
Group: DynoMotion Message: 12720 From: Tom Kerekes Date: 1/19/2016
Subject: Re: Can not move axis when Limit swich on
What Limit Switch Mode are you selecting?
Do you have separate inputs for each end of travel?
What Version of KMotion are you running?
www.avast.com
